TH-37PE30B & PC connection
Discussion in 'Plasma TVs Forum' started by 540YMX, Jul 3, 2004.
  1. 540YMX
    540YMX
    Jun 6, 2004
    37
    +3
    Had the display for 4 weeks now and very pleased so far. Today I connected my laptop and the output is best described as fuzzy, any suggestions how to correct this if that is possible.
  2. David PluggedIn
    David PluggedIn
    Oct 14, 2003
    544
    +10
    what connection are you using? you should use either VGA for best results, if you are using an SVideo connection or composite connection (available on some newer laptops) then the results will always be poor for any desktop type applications
  3. 540YMX
    540YMX
    Jun 6, 2004
    37
    +3
    Using the VGA port on a Dell laptop.
  4. cowtipper
    cowtipper
    Jan 29, 2004
    165
    19
    have you tryed turning the refresh frequency down and what screen res are your running at i would reccomend 800X600 anything over that and you will be giving the on board scaler a hard time trying to downscale to the native res
  5. 540YMX
    540YMX
    Jun 6, 2004
    37
    +3
    Tried the lowest res and made no difference, not able to change the freq so can't expirment with that unfortunately.
  6. cowtipper
    cowtipper
    Jan 29, 2004
    165
    19
    I have a 32pe30 i will hook my laptop up to it over the next week and see how it goes
