tft sharpness
Discussion in 'Desktop & Laptop Computers Forum' started by H4r7y, Jan 13, 2004.
  1. H4r7y
    H4r7y
    Jun 17, 2003
    1,701
    39
    Nottingham
    is there any sort of program that would enable a tft monitor to be a bit sharper with the picture quality?
    just finding it a bit annoying for games as opposed to a crt
    just a wonder
  2. Kramer
    Kramer
    If it's motion "blurring" you're referring to, nothing can be done apart from sourcing a faster response panel (Hitachi CML174, NEC etc.).
    Other usuals are make sure your running at native resolution via DVI (if possible).
    :smoke:
  3. H4r7y
    H4r7y
    Jun 17, 2003
    1,701
    39
    Nottingham
    yeah its the bluring when theres a fast game etc.
    ahh well, ill just have to keep living with it
    thanks for the reply though
  4. kryten
    kryten
    Apr 9, 2003
    515
    Swindon
    +14
    which tft? they are not all the same and the 'response times' are not much use in determining their gaming potential.
    check tomshardware.com for some good reviews.
    I've got a pair of Hyundai Q17s which are excellent when fed from my dual DVI card.
