TFT help needed
Discussion in 'Desktop & Laptop Computers Forum' started by miniman, Mar 13, 2005.
  1. miniman
    miniman
    Apr 14, 2003
    568
    Birmingham
    +7
    I am about to buy a 17" or 19" monitor (19" if i get my way :D ) and i was wondering if a dvi connection makes any difference to picture quality. I will not watch movies or play games on it, but will using a dvi give a better result for normal use. Thanks Mark
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    As usual there's no easy answer. :)
    In principle yes it does, however if the panel itself is poor then a better quality panel with only analog could still better it. In the case of my old Eizo both analog and digital produce excellent results and it's hard to know which is which unless you see the OSD when you select it.
    That said, if all else is equal then go for the one with DVI.
  3. miniman
    miniman
    Apr 14, 2003
    568
    Birmingham
    +7
    Thanks for the reply. The digimate from aria.co.uk it is then. Its a bit ugly but i have read some good reviews so i will give it a go.
