Tf1 Hd
Discussion in 'General TV Discussions Forum' started by Muf, Feb 11, 2005.
  1. Muf
    Muf
    Sep 11, 2003
    412
    IRL
    +8
    TF1 HD test has started on Hotbird again but it is scrambled at the moment.
    11013, H, 27500
    AFAIK this is the HD forum loop which has also appeared on 21.6E today (unscrambled) and has dissappeared from 5W.
    Jim.
  2. Hellicopter
    Hellicopter
    Jan 26, 2002
    331
    +5
    In the clear on my Quali box but sound in Mpeg2 is intermittently no signal and mute in the Dolby option.
    Anybody else having this problem?
    Alan
  3. Hellicopter
    Hellicopter
    Jan 26, 2002
    331
    +5
    Is it still on 21e and if so with what parameters?
    Alan
  4. Muf
    Muf
    Sep 11, 2003
    412
    IRL
    +8
    Hi Alan, Yes I got it eventually yesterday by selecting the mpeg2 audio and as you say the ac3 audio is blank. The mpeg audio comes and goes as you describe. The channel shows as scrambled in MyTheatre with Irdeto and Viaccess/TPS. The loop looks exactly the same as it was on 5W except the grey line at the bottom (over scan) is gone. The transmission at 21.5 E is 12520, H, 21700, I was getting a very weak signal from there even with 1.1 Metre dish, the footprint must be focused elsewhere.
    It is interesting that they are continuing with MPEG2, I suppose the fact that the new receivers are going to be dual standard MPEG2 & MPEG4 will allow them to switch easily at a later date. By the way HD1 will not switch off the MPEG2, HD1 transmission until 2008.
    Jim.
