Text Message Vibrate Alert
Rookies
Ok
I have just got a Samsung S5 moving over from iPhone and the vibrate alert for text on iPhone was great. I could change it. How do we change it on the S5 if we can please... as I am hard of hearing
UberCoder
Established Member
I think if you go into the text message app then open the settings menu. Somewhere in there it will say about notifications, ringtone, and vibrate. Just check next to vibrate and that should do it.
Rookies
Can't appear to be able to change the vibrate pattern at all for text alert is there a app for this too as that light app is great thanks. Cheers
RandomLee
I think the Light app might be able to do that, based on the description from Play Store...
You can also set repeating sounds or vibration patterns for each notification type
I'd guess the option is buried in the settings somewhere ;)
simplicity96
I use textra from the play store which is a better app for messages and you can set all details of your notifications including custom vibrate lengths etc.
Rookies
Thank guys going to look into all these...
Sony A84L/A80L BRAVIA XR OLED TV Review - COMPARED to LG C3, Samsung QD-OLED & LG G3
Back
