Tevion TCHTS2000 Home Theatre System
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Type23, Sep 23, 2004.
  1. Type23
    Type23
    Didn't discover it :blush:
    Really easy to hack :
    To convert this player to Multi-Region
    1. Press the Menu button on your remote control
    2. Press the 1 button on your remote control
    3. Press the 6 button on your remote control
    4. Press the 7 button on your remote control
    5. Press 1 for Region 1, 2 for Region 2, and so on, or alternatively Mute button on your remote control for All Regions
    Tried it with both R1 and R2 no problem !
    Impressed with quality so far, system gives a really loud sound/range. For £59.99 a nice little number for my bedroom.
    Rgds
    Rich
  2. s mcneil
    s mcneil
    The lead from the bass unit (multi to 6 phono plugs) is damaged. Does anyone know where I can get a replacement?
  3. Phil K
    Phil K
    Mar 6, 2005
    68
    9
    Well, I've got a Tevion DVD writer and this doesnt work on it.
    Anyone know another that will work ?
    And I've found it is very choosy in playing copied discs.
    Beware if you see it in Aldi stores. Even writing, sometimes the timer wont work, and what you've set the thing for hasnt recorded. Thought it was me at first forgetting something. Its happened to often to be that, and the thing you've preg'd had gone next day as if it HAS recorded - only the disc is still blank.
  4. Hackeroonie
    Hackeroonie
    Dec 2, 2005
    252
    Cardiff...Wales
    +18
    The Model number would help !
  5. paffren
    paffren
    Jan 15, 2006
    98
    11
    Derbyshire
    +3
    I have the 160gig HDD/DVD MD 80857 writer and it works fine. There's a firmware update on the medion.co.uk site (same company) which fixed any problems mine had, mainly locking up and shutting down mid recording. It plays divx as well which is a good feature.
  6. paffren
    paffren
    Jan 15, 2006
    98
    11
    Derbyshire
    +3
    There's a remote hack for it as well. It's in the hack section on the forum and it works.
  7. grahamtabby
    grahamtabby
    does anyone know the code to unlock the tevion tchts2100 dvd player? i tried this one (for the 2000) but it didn't work,
