Tevion MD 80857 - Have Igot a Noisy fan?
Discussion in 'Blu-ray & DVD Players & Recorders' started by pipecleaner, Oct 26, 2005.
  1. pipecleaner
    pipecleaner
    Hi folks
    Just bought a Tevion MD 80857 from Aldi and getting to grips with it. It seems to be working OK but the fan is quite noisy - more so than my PC. Now I don't know if this is just how it is or, whether there is a problem. I'd be grateful if anyone out there with the same machine could comment on just how noisy (or not) the fan in theirs is?http://www.avforums.com/forums/newthread.php#
    Smashin
  2. ROYOLD
    ROYOLD
    Jul 5, 2005
    3,898
    103
    Royton, Oldham. Lancs.
    +296
  3. pipecleaner
    pipecleaner
    Yes it is.
    Unfortunately there doesn't seem to be anything in the thread about the fan though.
  4. ROYOLD
    ROYOLD
    Jul 5, 2005
    3,898
    103
    +296
    With all the other faults mentioned I should think that a noisy fan will be the least of your problems. Maybe you could use that as a reason for returning it - should you so wish.
