Tevion Home Cinema
Discussion in 'Home Cinema Buying & Building' started by Davemazo, Jul 24, 2005.
  1. Davemazo
    Davemazo
    May 29, 2005
    886
    +37
    I`m new to home cinema and was looking for a cheapish home cinema system to go with my newly bought Tevion 32" LCD, Samsung HD850 DVD, Samsung DVDR-100e recorder and Sky+. I bought the Tevion system from Aldi in this weeks special offers because it seemed cheap and I liked the speakers already on stands making it easier to install. After reading this forum I gathered that the best way to connect audio is via optical cables so I was disappointed to find that the Tevion only had 5.1 phono connectors (one set) and an aux connection. Am I expecting too much at this price (£99.99) or is there something available with optical connectors at this price. I didn`t bother taking it out of the box when I saw this and took it straight back.
  2. Davemazo
    Davemazo
    May 29, 2005
    886
    +37
    Doesn`t matter now. I`ve decided to go for the Yamaha RX-sl80 and nsp-240 speaker package, £200 at Peter Tyson. I think I`ve made a big mistake though, it`s so complicated and the manual makes no sense to me. The sub-woofer just seems to sit there and do nothing. Any help on this would be appreciated.
  3. rozzar
    rozzar
    Sep 29, 2002
    1,055
    41
    Braintree
    +23
    have you gone into the amps menu and changed the bass setting to 'sub'. It may be switched to 'off, or none'
  4. Davemazo
    Davemazo
    May 29, 2005
    886
    +37
    Thanks, sub is on yes maybe I just need to turn it up a bit. Are you using the RX-SL80? if so can you get the menu to display on the TV? All I get is a rolling screen and have to use the display on the amp
