Tevion DVD8001
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by johnno11, Sep 6, 2007.
  1. johnno11
    johnno11
    I've just picked up a Tevion HDMI DVD player from Aldi today. Got it home, hooked her up, sorted.:smashin:
    Problem is, I could do with it being region free. I've had a search around the net, but no good. Anyone know a hack for it yet?
  2. radical1
    radical1
    Dec 18, 2006
    260
    Birmingham
    +11
    open tray - press 9999 on remote control - then the number "9" appears top right hand side of screen... job done :thumbsup:
  3. neuty
    neuty
    Oct 7, 2004
    6,160
    Cannock
    +932
    I think the player is the DVD8006 if so
    "Open CD tray, on the remote control pres 9999 you will then see the number 9 appear in top right hand corner of screen "
    copied from radical1 post(thanks )
    neuty
    radical1 beat me to it
    .no probs
    hope its a good player just advised my in-laws to buy it
  4. johnno11
    johnno11
    Awesome!!! You guys are legendary, thanks very much.:thumbsup::clap:
  5. radical1
    radical1
    Dec 18, 2006
    260
    Birmingham
    +11
    LOL - Im hot off the mark tonight Neuty! PS - check my thread about this player - I been trialing it all day, the thread may be of interest to you..
    http://www.avforums.com/forums/showthread.php?t=613859&goto=newpost
  6. makamo36
    makamo36
    Oct 3, 2007
    3
    I have just purchased a tevion dvd8001 but it doesn’t seem to be able to play DVD-R it either reads them as a bad disk or opens the root as if you were exploring the disc on a computer. As I have over 350 VHS films backed up to DVD-R discs this could prove to be a problem. The box and manual says it will play DVD-RW which it will as I burnt one to try. Has any one else had any problems like this or is it a standard problem
