Tevion 27" lcd tv - HELP
Discussion in 'LCD & LED LCD TVs Forum' started by halo2ster, Jan 2, 2005.
Tags:
  1. halo2ster
    halo2ster
    Hi All,
    I had recently bought a Tevion lcd tv which i am having problems with.
    When my scart lead is connected to the scart 2 slot it intermittently keeps blinking and shows on the screen "av searching". this gets quite annoying sometimes and dont know what to do?
    The scart 1 slot is fine. This only seems to happen in scart 2. Its usually fine for a while then starts acting up. Ive noticed that if i switch the power off and back on it works for a while before doing it again.
    Can anyone help? Would this be a problem with the tv itself?
  2. SLIM
    SLIM
    Jan 1, 2004
    1,364
    38
    +17
    Hello m8 the scart 2 is rgb and it realy ent any good i hade my xbox on it and it suck't looked realy bad i think you will find its just crap
  3. Binternet
    Binternet
    Oct 30, 2004
    190
    Sunderland/Newcastle
    Yea i had the same problem as you, and found that it stopped when i put my DVD in 4:3 rather than 16:9. I took it back though and found the RGB quality was crap.
