TEVION 27 HIGH DEFINITION LCD - Do 720p/1080i work?
Discussion in 'LCD & LED LCD TVs Forum' started by ocat1979, Jul 7, 2005.
Tags:
  1. ocat1979
    ocat1979
    I'm from Australia and looking at getting this LCD
    http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&category=11073&item=5786890915&rd=1
    I would like to know if anyone knows if 720p and 1080i res. works correctly via SCART with a Component/SCART adapter or via Component/DVI. I know the 32" model has a major problem with this and requires a firmware upgrade. Just can't find any info on this for the 27" model.
    I will be using it mostly for Xbox with Hi-Def AV pack, and DVD in my bedroom (PC connection won't be used), so it is a major issue for me.
    Any help would be great.
    Cheers :thumbsup:
