testing wf100
Discussion in 'Satellite TV, Sky TV & FreeSat' started by hitz, Feb 6, 2009.
  1. hitz
    hitz
    Dec 18, 2001
    68
    Hi All,
    I need some advise on how i can test wf100 (twin).
    I am at first fix stage - and all the cables from each room go back to a central room. These will connect into a 8 way loft box (labgear)- which will be connected to a dish once im ready to order sky.
    I need some way of testing that the wf100 twin is working correctly before the builders start plastering up the walls.
    Their is no aeriel / sky dish at the moment - so this not an option yet.
    Any ideas how i can achieve this ?
    Also - is it possible to extend twin wf100 if a run is a little short? i know its not ideal - but is their any disadvantage if its possible ?
    Thanks in advance.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    Maplin sell a Coax cable tester (just a simple continuity test)... You can extended the cables use F connectors and barrels if you have to.
  3. GaryB
    GaryB
    Nov 12, 2002
    5,393
    St Albans
    +1,303
    If you just want to test continuity, you can do that with a basic multimeter on the Ohms setting if you have one handy. Just twist the core & screen together at one end and connect the multimeter's probes to the other end. You should get a very low reading - around 0.5-2 ohms depending on the length of the cable.
    As HD says, you can join the cables with F connectors, but you should avoid doing so if at all possible.
