Testing Shutter Lag
Discussion in 'Photography Forums' started by Garrett, Dec 7, 2004.
  1. Garrett
    Garrett
    Apr 21, 2001
    40,800
    2
    167
    The best thief you’ll never see.
    +6,882
    It was shown on the Gadget show how to roughly test the shutter lag on you camera. Get some paper and make a pointer put it on a turntable at 33 1/3 rmp. Have the pointer pointing outwards. When the pointer reaches the 12o’clock position click the camera and see where the picture is taken.
    I just tested mine and here are the calculations 60/33.33 equals 1.8 seconds per rev. as mine was about 7.5 minutes position on the turntable(1.8/60)*7.5 equals .225 of a second lag.
  2. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
    This needs more qualification -
    for example are you pre-focusing if using auto-focus, or indeed are you using manual focus.
    Also your photo Garrett appears to have been taken with quite a large shutter time?
    Unfortunately I don't have a turntable to test this (what are they anyway... some old fangled thing no doubt...?! Can I use a cd player!!?!) but am pretty sure that pre-focused my Canon A80 would be quicker than .225 seconds.
    Reviews at Steves-Digicams normally give a good indication of shutter lag.
  3. monocrider
    monocrider
    More to the point, how do you know you pressed the shutter at the precise moment the arrow reached 12 o'clock ? Surely you could easily be 0.1 seconds or more either way because of human error ?
  4. Blu Ray
    Blu Ray
    Jun 14, 2004
    496
    Chorley, Lancs
    +12
    Also, not many people have turntables any more, I certainly havent had one for nearly 20 years!
  5. paulc1
    paulc1
    Oct 19, 2004
    397
    +27
    my fuji finepix s602 has a shtter lag of about 1 week, even if you pre focus, it looks like a great idea but somewhat approximate :).
  6. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +226
    If you've a digital watch hanging around start its stopwatch and just take a snap say when it reaches 10sec, the time displayed in you're piccie will give an _idea_ of lag.
  7. RBZ5416
    RBZ5416
    Nov 4, 2002
    18,339
    +6,871
    What's the point?
    If you are forever missing shots then you already know that your camera suffers from delay. Or is the idea that next time you pop into Jessops for a demo, you go equipped with a turntable under your arm? :laugh:
    As Andrew said, the figures are readily available anyway....
