testing second-hand dvds
Discussion in 'Movie Forum' started by Peter O Sullivan, Jan 25, 2002.
  1. Peter O Sullivan
    Peter O Sullivan
    just wondering if this is possible. Is there a program for a PC you can get to test a dvd to see if it running properly, like if any minor scratches on it would affect the playback. It would be handy if buying a 2nd-hand dvd instead of playing the whole thing.
  2. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    So you're planning on lugging your PC around with you when you go shopping for 2nd hand DVDs?
    I think I'll stick to just taking them back to the shop.
    However, I think you can find such programs - inside every single DVD player. Sorry if I come across being a bit sarcastic... I've just had one of those days.
