Testing for RGB capable Scarts
Discussion in 'General TV Discussions Forum' started by Will_Marsh, Sep 26, 2004.
  1. Will_Marsh
    Will_Marsh
    I have just ordered a philips 32PW9509 from JL (pricematched) and have seen posts stating that there may be an issue with the RGB enabled scarts. Is there a quick way to test for them without any additional kit. I have a Pannie S75 DVD.
  2. Adcote
    Adcote
    Aug 28, 2004
    82
    Leicestershire
    I have this TV. There is no 'issue' really - 1 & 3 are RGB enabled; 2 is composite.
    When you switch to a SCART it tells you on the screen what sort of signal it is dealing with (i.e. RGB or CBVS)
  3. Will_Marsh
    Will_Marsh
    Thanks Microstar
