Testing Bad Geometry
Discussion in 'General TV Discussions Forum' started by Tony_Anon, Jan 8, 2004.
  1. Tony_Anon
    Tony_Anon
    What's the best way to test whether a tv set has bad geometry?
    Do you test for picture (pan and scan) or text scrolling (e.g text scrolling at bottom of page; stretched at sides).
    Are the Lucas THX programs on DVDs any good for checking geometry?
    I hae a Sony KV32FQ70U which exhibits the above effects. Should I get a refund/replace?
  2. Ashy
    Ashy
    Jan 3, 2003
    377
    +14
    hi mate
    not sure if this is what you mean but...
    ive got an FQ75 and it had rather dodgy geometry. the way i fixed it was to use the THX optimiser off Lilo & Stitch, pick the test that puts a rectangle round the a circle. then i went into the service menu and into the deflection menu and using this as a guide i got the rectangle to look spot on.
    sorted it out for me picture-wise
    hope that helps :)
