Question Testing a PA horn
Discussion in 'General Tech & Gadget Forums' started by weldaar, Apr 28, 2016.
Tags:
  1. weldaar
    weldaar
    Apr 28, 2016
    2
    4
    NJ
    I have an old set of PA cabinets (Yamaha S4115H) in my studio. The horns stopped working after a loud squeal. Not sure what caused it, but either way I would like to find out why? The speakers are working fine, but no horns on either cabinet. Is it possible to blow both coils (and or diaphragms) at the same time? Not even sure if they have diaphragms. How do I go about checking this? Not very well experienced with this. I do have a meter if that helps. Thank you all in advance for your help with this.
    Jeff
  2. rousetafarian
    rousetafarian
    Aug 17, 2007
    22,815
    2
    NW
    +14,790
    Welcome to AV Forums!
  3. weldaar
    weldaar
    Apr 28, 2016
    2
    4
    NJ
    I just found out how to test the coils. I check across them with my Multi Meter and they are indeed bad. I got an OL reading. I will get new ones, but I would like to ask about installing circuit breakers to avoid this problem in the future. Any recommendations?
  4. Bbos37
    Bbos37
    Mar 27, 2016
    192
    Malaysia
    +17
    From what I know there's no such beaker available for speakers.Protection has to be done from the power amp side.
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,173
    The Borders
    +3,379
