testing a headunit
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by ecynaxt, Sep 19, 2005.
  1. ecynaxt
    ecynaxt
    I need to test a headunit that I took out of my previous car before I sell it on eBay. I seem to remember that the matrix display was a bit faulty so I need to make sure its ok before I sell it.
    I want to just hook it up to the car battery with a few wires to get power to it so I can see if the display works. I don't need to hear it.
    What do I need to connect to what to get it working? Is there anyting I need to do to fool it into thinking the ignition is on?
    Its a kenwood minidisc headunit by the way.
    cheers
  2. beachbum
    beachbum
    Nov 26, 2004
    25
    I tested one recently using the car power source but you have to ensure the stereo is earthed as well (usually from the car too)
    I presume direct from battery would be ok but it must still be earthed.
    BB
  3. ecynaxt
    ecynaxt
    Can you earth it on a bit of exposed metal in the engine bay or does it have to be earthed to somewhere special.
    How exactly did you go about testing yours?
  4. Kevstir
    Kevstir
    Aug 22, 2005
    723
    46
    Falkirk
    +185
    if you have a car battery charger just hook it up to that :thumbsup:
  5. GaryB
    GaryB
    Nov 12, 2002
    5,387
    St Albans
    +1,294
    I wouldn't recommend that. The average car battery charger gives out far more than 12 volts off load. Also, it is unsmoothed, which will make most radios buzz rather loudly.
  6. Kevstir
    Kevstir
    Aug 22, 2005
    723
    46
    Falkirk
    +185
    done it a few times and never had any probs , also seen a guy using a head unit as his hifi in his room powered of and battery charger , to be safe though m8 just hook it up to the battery
    Kev
