Test Patterns
Discussion in 'Desktop & Laptop Computers Forum' started by garyc, Oct 28, 2005.
  1. garyc
    garyc
    Dec 21, 2002
    918
    Jersey, Channel Islands
    +17
    Can anyone recommend a good test pattern to help setup a htpc with different screen types. ie. lcd, crt proj etc
    I seem to remember a good one at the event 2 in guildford.
    cheers
    Gary
  2. dgc
    dgc
    May 1, 2003
    216
  3. Gordon @ Convergent AV
    Jul 13, 2000
    14,247
    +3,115
  4. fraggle
    fraggle
    Dec 11, 2002
    1,516
    Sugar Land, Texas
    +58
    If you are after a test pattern to check for 1:1 mapping do this:-
    Right click on an empty area of the Start bar and choose Task Manager.
    Select third tab called "Performance"
    Maximise the Task Manager window.
    Double click on either of the graphs.
    This will give you an almost full screen graph with single pixel horizontal and vertical lines. Using this its an absolute doddle to see when you have 1:1 mapping or not.
