Test new PC performance
Discussion in 'PC Gaming & Rigs' started by Peew971, Apr 26, 2016.
  1. Peew971
    Peew971
    Aug 14, 2007
    3,431
    +732
    I've just finished building my first pc and was wondering if there was any way/software to test its overall performance in case something is going wrong that I'm not aware of.
  2. boltlock
    boltlock
    Jul 13, 2006
    7,665
    Home
    +4,248
  3. Peew971
    Peew971
    Aug 14, 2007
    3,431
    +732
    Thanks. Does it test everything at once or do I need to follow-up with another program?
  4. boltlock
    boltlock
    Jul 13, 2006
    7,665
    Home
    +4,248
    It tests everything and gives you a score which you can then compare against similar PCs around the world.
  5. Peew971
    Peew971
    Aug 14, 2007
    3,431
    +732
    I'm not too sure what this means but I got a 6053.5 rating. Does getting there means everything works fine? Am I ready to dismantle my old pc now?
  6. Peew971
    Peew971
    Aug 14, 2007
    3,431
    +732
    And other scores...
  7. GMC79
    GMC79
    Apr 1, 2006
    10,593
    Glasgow
    +3,139
    Few others to try..
    Cpu stabilty, prime95 & intel burn test
    Graphics benchmark tests.. 3dmark (search steam),
    Unigine heaven and unigine valley.
    MSI kombuster.
    Search benchmark thread for comparisons.
  8. mozza54
    mozza54
    Aug 25, 2010
    3,298
    Rotherham
    +432
    I usually run Prime95 for a bit to make sure the cpu cooling is ok and its all running stable. For the GPU 3dmark is good or furmark if you want to stress it.
  9. Peew971
    Peew971
    Aug 14, 2007
    3,431
    +732
    Thank you lads. Should I run Prime95 for hours, what's the average length people use it for? Been on 20 mins now without issues.
  10. mozza54
    mozza54
    Aug 25, 2010
    3,298
    Rotherham
    +432
    I think theres specific sets of tests you can run.. I tend to just leave it ticking over for 30 minutes.. ish but your CPU should be up to its max temp after a few minutes. After 20 minutes, Id imagine your cpu will be at its upper limit, if the machine hasnt completely bombed out sounds like its stable as well.
  11. boltlock
    boltlock
    Jul 13, 2006
    7,665
    Home
    +4,248
    That's a very good score actually. If your system is stable then you should have nothing to worry about and can start dismantling the old one. :smashin:
  12. boltlock
    boltlock
    Jul 13, 2006
    7,665
    Home
    +4,248
    I'm not sure whether the test makes use of SLI but this is what I got for comparison.
  13. Peew971
    Peew971
    Aug 14, 2007
    3,431
    +732
    Nice :thumbsup:
    3D Mark on Steam is £18.99, am I looking at the right thing there?
  14. GMC79
    GMC79
    Apr 1, 2006
    10,593
    Glasgow
    +3,139
    I ran it earlier just to see and got 5355 (4770k & 970)
  15. boltlock
    boltlock
    Jul 13, 2006
    7,665
    Home
    +4,248
    That's the main gaming bench as used by most people. Again you can upload the results and compare against similar systems. :smashin:
  16. GMC79
    GMC79
    Apr 1, 2006
    10,593
    Glasgow
    +3,139
    Not really worth buying tho at that price unless want to fiddle. All test comparisons are done at same settings that are available on free version.
    Give it a go and posr in the benchmark thread. Could do with a revive
  17. Peew971
    Peew971
    Aug 14, 2007
    3,431
    +732
    I think I saw a demo indeed, will check again tomorrow. No sign of a benchmark thread though.
  18. Cha1ky
    Cha1ky
    Nov 26, 2007
    49,713
    The Internet
    +24,832
  19. RMGEE
    RMGEE
    Apr 28, 2006
    2,600
    Worcestershire
    +655
  20. shil
    shil
    Apr 13, 2006
    1,587
    116
    +831
    Also have a look at Aida64 its a hardware detection software and will give you details on memory/cpu speeds/spec etc... AIDA64 Extreme | AIDA64
