Test DVD?
Discussion in 'AV Receivers & Amplifiers' started by Newbie-Geoff, Aug 25, 2006.
Thread Status:
Not open for further replies.
  1. Newbie-Geoff
    Newbie-Geoff
    Aug 15, 2006
    14
    Southend-on-Sea
    Hi All,
    Just wondering - in your opinion what is the best DVD to test out a 5.1 (or 6.1/7.1) sound system?
    One that will make full use of the set up and full range of the speakers?
    :confused:
  2. rob roberts
    rob roberts
    May 7, 2006
    89
    +4
    Master and Commander the far side of the world, I use the battle scenes to show my system off to my friends. The DTS soundtrack is awesome and really pushes all the speakers.
    For 6 & 7.1 it has to be Blade 2, the DTS-ES mix is mental, the scene in the alleyway at the start of the film left me sat there with my mouth wide open going aaaaggghhhhh!!!!!!!!
    Thats my opinion,
    Hope it helps.
  3. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,035
    Harrow, NW London
    +600
    :D definitely!!
    hehe
    [Mod Comment - Knyght_byte: I'm going to close this thread as this question is asked repeatedly and if you use the search feature you will find the threads, although best to check the Movies and Films forum further down the list, i think there is a thread in there which has pretty much any film worth mentioning, also worth checking the subwoofer forum for films with very bassy moments :) :end Mod Comment]
Thread Status:
