Test data for players
Discussion in 'Blu-ray & DVD Players & Recorders' started by raigraphixs, Feb 12, 2002.
  1. raigraphixs
    raigraphixs
    Jul 11, 2001
    62,594
    +23,558
    Can someone give me some laymans explanation and ratings on test data marks used buy some mags.
    1. Video Jitter - ns (nanoseconds) the lower the number the better?.
    Explaination:
    2. Siginal to noise -
    Explaination:
    3. Frequency response (s-video) at 5.8mHz; higher or lower ratings are best?
    Explaination:
    4. Chroma AM/PM; higher/lower is better?
    Explaination:
    The reason i ask is that i see in many test data marks the results are very similar, but one player would get better picture marks than another with same test data results. This confuses me a bit. So are they saying test data is one thing, but seeing a dvd player live showing a film is another, though they may score the same, the picture, sound can vary?.
    Also at the moment i have a;
    tosh 2109b (old player) has a video jitter of 3ns, and the image is fantasic, but i would like to have component inputs.
    the new tosh510E has a jitter of 5ns,
    and a highend 900E has a jitter of 2ns.
    what do you make of this, if anything.
    regards
    rai
  2. bh
    bh
    Jul 14, 2000
    397
    Lost (no GPS here)!
    It's here on the HCC website:
    "Video jitter
    Here, we examine variations in the horizontal sync timing of the video signal on a single picture frame. With analogue VCRs, problems manifest themselves as lateral wobble of the picture and/or colour errors at the top of the screen. DVD suffers less from video jitter - even a 'poor' measurement will still be around 500 times better than a good VCR - you're unlikely to see an unstable picture from DVD. Lower jitter readings indicate a solid and mechanically stable transport.
    1 or 2ns: Excellent
    3 or 4ns: Very good
    5 or 6ns: Good
    7ns: Average
    7ns or more: Below average
    Chroma AM/PM
    These measurements set out to determine how good a DVD's colour performance is. Since the colour (chrominance) signal is sensitive to both amplitude (strength) and phase (timing) variations, two separate measurements are made - amplitude-modulation (AM) and phase-modulation (PM). The results are expressed in decibels below reference level. Problems here may result in low-level colour pictures that lack contrast. Look for chroma AM/PM readings of at least -68dB. Poorer performers will show a greater disparity between the AM and PM reading.
    68dB or more: Excellent
    66dB: Very good
    65dB: Good
    60dB: Average
    60dB or less: Below average
    Upper frequency response
    As with TVs and VCRs, this is the highest luminance frequency that can be resolved. Using a special 'multiburst' test DVD, we check the amplitude of the highest-frequency (5.8MHz) burst. The higher the figure the better. We assess both composite and S-video outputs.
    Composite video
    -4.5dB or more: Excellent
    -8.5dB to -4.5dB: Very good
    -9.5dB to -8.5dB: Good
    -10.5dB to -9.5dB: Average
    -10.5dB or less: Below average
    S-video
    -6dB or more: Excellent
    -8.5dB to -6dB: Very good
    -12dB or less: Below average
    Chroma crosstalk
    'S-video' stands for 'separate video' - chrominance and luminance paths are kept separate to aid performance. There is usually a tiny 'leakage' between the two, which can create a low-level 'moire' (colour patterning) effect. This test puts a precise figure on this leakage.
    -61dB or more: Excellent
    -59dB to -61dB: Very good
    -55dB to -59dB: Good
    -50dB to -55dB: Average
    -50dB or less: Below average
    Signal-to-noise ratio
    All electronic systems generate unwanted noise. It's not so much of a problem in the digital domain, but things are rather different when the signals are converted back into analogue. In video systems, noise is apparent as grain or low-level patterning. We measure the levels of noise that are added to a colour-bar pattern derived from a digitally-produced and mastered (it's noise-free) test DVD.
    76dB or more: Excellent
    73dB to 76dB: Very good
    70dB to 73dB: Good
    60dB to 70dB: Average
    Digital deviation
    Although sound quality is influenced by many different parameters, audio jitter leads to a lack of musicality or a softening of the bass amongst other things.
    180ps or less: Excellent (audiophile CD standards)
    180ps to 250ps: Very good
    250ps to 350ps: Good
    350ps to 500ps: Average
    500ps or more: Below average
    2,000ps or more: Terrible"
    Source
