If you type "Test CD" in the search engine above it will throw up some past threads on the subject. You should get some usefull information.
I tried it and found a signal generator download http://www.nch.com.au/action/index.html
If you do download this program remember to use the sinewave option only as the other functions may damage your speaker. Also a pure sinewave will warm your voice coil so best keep volume low.
Good Luck
Tom
Good Luck
Tom
