Test Card
Discussion in 'General TV Discussions Forum' started by Berisford, Jan 1, 2002.
  1. Berisford
    Berisford
    Nov 23, 2001
    269
    28
    Mansfield
    +49
    I'm having a little difficulty setting up the verticals and picture size on my Sony 28FQ75.
    Does anyone know if the BBC still transmit a test card at any time?
    Cheers BJ Notts.
  2. Paul O
    Paul O
    Nov 2, 2000
    481
    UK
    +21
    I don't think they do now. 24 hour service.
    If you have a DVD player, you can buy a DVD with lots of testcards and sound tests on it.
    I forget the name of it, and its rather expensive though. Ask in the DVD forum for the name, and you might be able to rent it from the video store?
    Cheers,
    Paul..
  3. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
    AVIA or Video Essentials are two with test patterns in NTSC.
    Referenz DVD is another with PAL patterns.
    TAG DVD player has built in test patterns.
    If you have foreign satellite you will find many channels broadcast test patterns when not broadcasting material.
    Do any THX optimiser discs have patterns?
    Gordon
  4. RATMARK
    RATMARK
    you can get the " ulitmate dvd" from hmv about 30quid
    has loads of screen set ups
    geom, convergence,purity screens , clamp tests and more then there loads to set up your audio as well then you gett a disk full of surround music and videos etc
    this will help you get sorted
