terryscan terrestrial meter
Discussion in 'Freeview & YouView' started by jhaye2x, Sep 11, 2012.
  1. jhaye2x
    jhaye2x
    Aug 30, 2011
    2
    hi all ,i have bought a terryscan terrestrial meter 2nd hand.it is in good condition and it scans perfect.the one thing i do not understand is the gain and how it works. .i tried the swires website .it does not give much info.any help would be great. jhaye2x
  2. Rodders53
    Rodders53
    Dec 8, 2007
    5,131
    Bedford
    +918
    I have no firm idea (not being familiar with that unit), but I assume it allows the operator to increase/decrease the system gain so as to get the carrier/signal peaks into the display without clipping and/or to try to see a carrier close to the noise floor?
    It should have come with a manual which may tell you more? Swires may supply a copy if you ask them?
    What happens when you press the gain buttons (and are connected to a working aerial).
