Rob100
Okay I've owned my Denon 3805 for a few years now and it has served me well.
In our old house (when in the lounge) I ran the set-up and normally settled for either 'normal' or 'front' EQ modes and was happy with the sound.
Ever since moving the 3805 into my new room (different house) about a year ago I've struggled with the sound and have found it sounding best (by a mile!) with EQ off, something I have to do anyway when using ext-in from HD-A1.
I don't know if it's something funny affecting the results with my (dedicated) room, but I've tried using the supplied mic and also using the phono output from my SPL meter into v.aux L and in both cases get very similar results. The results are terrible. Distances and speaker types and reasonably well detected, but the EQ is cr*p.
To my ears, just increasing the top end (top 4 frequencies in manual EQ list) by 0.5 to 2db (when in manual EQ) adds a little extra sparkle and clarity to vocals without sounding over bright or harsh.
Front speakers are AE 309 floorstanders and AE 307 centre.
For example, these are the results for Front L on 'normal' after running the set-up:
50Hz / Q 0.5 / Gain -2
110Hz / Q 0.5 / Gain -2.5
200Hz / Q 0.9 / Gain +7.5
1.4kHz / Q 0.5 / Gain +3
5.1kHz / Q 0.9 / Gain -7
7.2kHz / Q 0.9 / Gain -2.5
10kHz / Q 0.9 / Gain +9
14kHz / Q 0.5 / Gain +6
There seems to be big swings in + and - gains, seems odd to me?? Sounds awful.
Any ideas?
Thanks,
Rob
Any ideas?
Thanks,
Rob
