Terrible CD recording quality Keane Hopes and Fears
Discussion in 'Music & Music Streaming Services' started by Crocodile JD, Feb 4, 2005.
  1. Crocodile JD
    Crocodile JD
    Dec 11, 2002
    1,081
    41
    Tamworth, Staffs
    +21
    Is it just me or just my recording? It sounds badly distorted at times. It can be heard specifically on track 11 (Untitled 1) from the start over the instrumental intro. There is a snare drum that comes in and it sounds like someone is scrunching up a plastic bag it is so distorted. Also, on 26 seconds, it reminds me of my vinyl days when someone would knock the turntable and you got that horrible stylus wobble in the sound. It's very distinctive and that is just one of them, there are several. I have the so called special edition which is the one with the black cover (ref: CID8145/986657-3 if that means anything?).
    Would you give your copy a listen and LMK. Also what about other CDs with bad production quality?
    I really want to find out because I've just installed a PC based system at work - M-audio sound card, Foorbar software player (ASIO enabled), headsave headphone amp and Sennheiser cans. The problem is that it seems very analytical to the point where I can pick up faults in many of my CDs that I hadn't heard before. Obviously I've tried the Keane album on other kit to be sure it wasn't my new kit and the errors are still there, but what experiences have you had?
    Croc
  2. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,727
    71
    Land of the Living, Essex
    +35
    Are you using replay gain?
  3. Crocodile JD
    Crocodile JD
    Dec 11, 2002
    1,081
    41
    Tamworth, Staffs
    +21
    I do have Replygain enabled in the Playback preferrences although I believe you have to scan the tracks to actually activate it. It adds/modifies the code. I did scan the CD which seemed ok but it gives an error on playback to say that it couldn't play a modified file and just plays the original. I think it only works on files that have been burned to hard drive, as mine are on CD it won't modify those.
  4. ihan
    ihan
    Sep 10, 2004
    624
    28
    Stockport
    +25
    Hi Crocodile JD,
    You're quite right - it is badly distorted. If you play the disc in media player with the oscilloscope enabled, then you can clearly see 'clipping' occuring. It's a shame really for such a good album.
    Regards,
    Ian
  5. JiMbOb_74
    JiMbOb_74
    I think you will find the sound is meant to be like that... Just like most electric guitars are through distorting pedals...
    I may be wrong but the only people who will be able to tell you is keane themselves or their producer...
    Anyway stop looking for faults and enjoy the music of one of the best new bands for years
  6. Starvald
    Starvald
    Jan 6, 2005
    55
    Liverpool
    Starnge, I can hear (a little) the distortion you talk about, but it doesn't strike me as bad. I agree with jimbob, I think it's meant to be there.
    I also think that this album is one of the better recorded/produced ones that I've heard. I tend to think bad ones are those that have been compressed (the treble seems to lose definition, and become harsh) or just badly produced (they sound lifeless).
    It could just be that your equipment is more capable than mine, though.
  7. Crocodile JD
    Crocodile JD
    Dec 11, 2002
    1,081
    41
    Tamworth, Staffs
    +21
    ....don't get me wrong guys I love the album, I agree with Ian, with such great music it's a real shame that it is so badly produced
    come on JiMbOb_74 you must be kidding? check out 26 seconds on track 11, no way is that right, it sounds really bad. :thumbsdow Try it with headphones if you've got them, you can't miss it.
    Croc
  8. PJTX100
    PJTX100
    Dec 21, 2004
    8,134
    +564
    hmm I'll give this a try, I've heard distortion in one particular place (the ending to untitled 1 I think - I'll double check) and that's clearly meant to be there.
    The opening synths on Bedshaped are a real speaker tearer.
    Fantastic album - have the SACD on order...PJ
    Update: Re-reading this I presume you must mean the last 26 secs where the percussion goes distorted, as I said it's meant to be like that...
