Terminator SE menu audio problem
Discussion in 'Movie Forum' started by eerkel, May 24, 2001.
  1. eerkel
    eerkel
    I just recently bought Terminator (1) Special Editon R2. I noticed that there is no dolby digital menu sound ?!? The menu sound is only in dolby surround? So when I have set my receiver to play dolby digital I do not hear any menu sounds.
    Is this a known problem or is this a problem with my DVD disc or DVD player (Pioneer 535)?
    Anyone?
    Cheers,
    Eddy Erkel
    Waalwijk, The Netherlands
  2. Russ
    Russ
    Aug 3, 2000
    214
    Warwick, UK
    +16
    HI
    Mine does the same !
    There is 2 channel sound (output through scart I guess) but for some reason S/P-DIF doesnt output correctly.
    I have tried two different (£200 and £1000) DVD players (The latter with the Denon flagship amp) with the same result.
