Terminator ( Bloom on Disc ? )
Discussion in 'Movie Forum' started by B Caine, Mar 20, 2003.
  1. B Caine
    B Caine
    Jul 15, 2000
    80
    Barrow North UK
    +3
    I have just checked my T1 disc and have found a bloom just under the surface, it playes ok but is this the rot that people have been talking about? if so will it get worse? It is a R2 disc so if I order one from R1 and it being a more recent one would that be a safer bet? Many thanks for any replies that I may recieve.
  2. Sam Fox
    Sam Fox
    Yes there is a fault with the disc. MGM will replace it for you. There is a thread on here somewhere that has the details.
  3. B Caine
    B Caine
    Jul 15, 2000
    80
    Barrow North UK
    +3
    Many thanks Sam, I shall dig around and see if I can find anything. Thank You.
  4. Geezer
    Geezer
    Aug 5, 2002
    2,813
    68
    +25
    Just do a search for dvd rot and you will find the thread, i sent mine back two weeks ago.
