Terminator 2 WMD-HD DVD
Discussion in 'Televisions' started by Neil69, Sep 10, 2005.
  1. Neil69
    Neil69
    Jun 8, 2001
    306
    Leigh
    +14
    :thumbsdow :eek: Hi, I'm sorry if this has been asked a million times before, but I was wondering if ANYONE has managed to get their PC to run the Windows HD-DVD version of Terminator 2? I've played the SD version of it & the picture is truly awesome. I just want to compare the two versions.
    Ta, Neil
    :hiya:
  2. dan1979
    dan1979
    Sep 16, 2004
    3,520
    83
    +201
  3. Jim_Fear
    Jim_Fear
    May 17, 2005
    1,799
    Caterham
    +59
    I#ve seen a few of the copies floating about on ebay and aparently they are designed to be run using WMP9, i've tried to pick up a copy but I keep forgetting or being outbid at last moment, I'll get one sooner or later though. A shop down the road from my college used to play clips from the xtreme version on a high def panel and I must say it did look rather awesome, the only thing I can suggest is to possible try and pick up a copy and compare it that way, everyone see's things differently so while it may look awesome to someones eyes, the image quality may not be noticable to another person
  4. splnter
    splnter
    Oct 20, 2003
    517
    Basingstoke. Hampshire
    +25
  5. Neil69
    Neil69
    Jun 8, 2001
    306
    Leigh
    +14
    Hi, thanks for your replies. Well, I got my copy from Playusa.com
    Cheers, Neil
