Terminator 2 - Judgement Day SE/UE (R1)
Discussion in 'Movie Forum' started by Reiner, Oct 14, 2001.
  1. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Just to clarify this: is it correct there are two versions with DTS, i.e. one SE and one UE (the latter in a box w/ 2 DVD)?
    Any difference in the picture or sound quality or do I assume correctly that the SE is just the 1st disc from the UE (without the disc with the extras)?
    Since I am not so much into the extras I might be happy with the SE before spending more on the UE ...
    [ 14-10-2001: Message edited by: Reiner ]
  2. Confucius
    Confucius
    Feb 1, 2001
    2,150
    Oxford
    +132
    The initial R1 release of T2 (October '97) was a DVD-9: just the standard theatrical version of the movie.
    Last August it was released as T2 the ultimate edition in an aluminium slip case. At first it was planned to be a DVD-18 only release although I believe that in order to increase production (or production problems?) it was also available as a 2 x DVD-9 release. I have the latter, and as far as I know there is no difference in the packaging between the two (2 x DVD-9/1 x DVD-18), outwardly at least - the actual disc content is identical.
    I think the only version available named as a 'special edition' was one of the many Laserdisc releases.
    IMDb DVD
    IMDb Laserdisc
    [ 14-10-2001: Message edited by: Confucius ]
  3. Dave H
    Dave H
    Aug 20, 2000
    4,393
    Lots of different places!
    +144
    i have the DVD 18 :D
  4. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    I do have the first release but I am just a bit confused as www.dvdboxoffice.com list the UE and www.dvdempire.com only offers the SE.
    I had the UE in my hands yesterday but I don't think it was a aluminium case (just cardboard)!? May need to check again ... but if I can get the SE cheaper I will go for that.
    Hm, just noticed when you click on the cover/back of the SE it clearly says UE, so it's most probably the same (without the extras) ...
  5. Confucius
    Confucius
    Feb 1, 2001
    2,150
    Oxford
    +132
    Just had a look at DVD Empire, that's the UE (incorrectly called SE by them).
    Trust me! there is no (R1) DVD labeled as SE. I'm also pretty sure the original release is now discontinued.
    The extras on the DVD-18 and 2 x DVD-9 UEs are identical.
  6. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,658
    7
    167
    Birmingham, UK
    +10,544
    See the news item on Total DVD dated 15th Oct.
  7. Ars longa, vita brevis
    wow, that ong ago. that's impressive
    i'm pretty sure the original was pulled, although in saying that, in hmv you can still buy the original r2 se7en for £20 and get the new 2 disc dts one for a tenner, how odd. Perhaps i ought to say could as the offer may have ended with regard to that particular title.
