Terminator 2, DTS, Audio cutting out
Discussion in 'Xbox Forums' started by Spinke, Sep 22, 2007.
  1. Spinke
    Spinke
    Dec 20, 2006
    2,805
    Coventry, UK
    +608
    I'm not sure what the culprit is for this,
    If I set the 360 to output DTS with Terminator 2 the audio will cut out at random moments. If I change it to Digital 5.1 the audio is fine, but obviously doesn't sound quite as good.
    I've tried The Pianist with the same options and it's fine on both :confused:.
    Has anyone else experienced the same thing? Kit is in sig.
