terminating lan cables into a modular faceplate system
noviceinstaller
I was just wondering if it is feasable to terminate one end of a lan cable to a modular faceplate, and keep the other end as a connector into my router? Not sure but have heard there is an A and B setting when using modular faceplates, if so which wire fitting should i be using, A or B???:confused:
Kristian
It depends on the cable. If your cable is solid core then you can terminate one end on a module and another on a plug. If your cable is stranded then a plug fits well but it won't terminate into an IDC well. Make sure you get the right type of plug for the cable, stranded or solid.
There are two standards for Cat5 termination, TIA 568A and TIA 568B. As long as you stick the same standard at each end of the cable it'll work fine. The method that seems most popular, which is in use at all the places I've seen is 568B.
mickevh
All UTP has twisted pairs ('swot the "TP" means.)
Are you referring to th difference between "solid" and "stranded" (AKA "patch") cable....?
