Terminated in Glasgow!
Discussion in 'Cables & Switches' started by Mark Pitchford, Jul 14, 2004.
  1. Mark Pitchford
    Mark Pitchford
    Mar 9, 2001
    206
    Scotland
    +4
    I've got a 15m 5 core video-grade cable that was installed in a new extension that we had built last year.
    Now, I've only just gotten around to buying a projector so who could terminate this cable for me in the Glasgow area?
    The cable will be going between a DV89 and a Screenplay 7200.
    Thanks,
    Mark
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,270
    The Borders
    +2,572
    Mark
    Drop me a PM and I'll put you in touch with my brother - he's pretty handy with a Soldering Iron and Crimp tool.
    If you can have details of the cable you've installed that will be handy as it'll determine which connectors he uses.
    Best regards
    Joe
  3. Gordon @ Convergent AV
    Jul 13, 2000
    13,999
    +2,803
    Joe: It's RGB communicatons 75ohm mini co-ax. Not sure what crimp plugs etc you'll need. Might want to call Ian to confirm they haven't changed to extron cable from RGB......
    Gordon
  4. Chaos Star
    Chaos Star
    Jan 9, 2003
    1,264
    38
    Scotland
    +18
    Best to get some one with canare crimping tools to sort to it - not a big fan of solder my self. Canare plugs are also excellent for termination.
  5. Mark Pitchford
    Mark Pitchford
    Mar 9, 2001
    206
    Scotland
    +4
    Joe,
    Do you know the cable?
    I'm after the best plugs I can get to fit!
  6. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
    Why ? We always use solder wher appropriate to make connections. The only time i'd freely use cripmed connections is in car audio installs.
  7. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    I solder my connections, but there's no reason why you couldn't crimp and then silver solder just to be sure.
    I think he was only using the Canare crimping equipment though.
    Slightly off topic, but why are car installs crimped and not soldered?
  8. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,270
    The Borders
    +2,572
    Hello Mark
    Crimp, Solder, Weld, Glue - you name it we've done it.
    Little brother's even built the odd Frigate or two!!!
    As before drop me a PM and I'll put you in touch and you can discuss your requirements.
    Best regards
    Joe
    PS See what we do in our spare time - http://www.tmfsolutions.co.uk/case_study.htm
  9. Mark Pitchford
    Mark Pitchford
    Mar 9, 2001
    206
    Scotland
    +4
    Joe,
    You have PM!
  10. Chaos Star
    Chaos Star
    Jan 9, 2003
    1,264
    38
    Scotland
    +18
    Sorry I was meaning cannare crimps and plugs - no solder!
