Terminal boards
Discussion in 'Plasma TVs' started by franc, Jan 18, 2003.
  1. franc
    franc
    Sep 12, 2002
    437
    Bucks
    +7
    hi, are the Panasonic series 5 plasma terminal boards easy to change? Can it be done by the user or does it need expert help?
    thanks again, FRANC
  2. Bonzaimaster
    Bonzaimaster
    Feb 8, 2002
    182
    16
    London
    They are very easy to change. It's a five minute job.
  3. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    5 minutes if you have a tea break.
  4. franc
    franc
    Sep 12, 2002
    437
    Bucks
    +7
    I take it, it just tugs out like say, a PC card from a slot. I think there are a few screws in it too. Do these need to be removed also . I havent looked for a while and where it is hung, it is a little tricky (I will will have to cross the 'spagetti-junction' that is the back of my amp! :eek: )
    Also, are the boards region specific? Could you, for example put a board from say the US, into a UK Plasma or vice versa?
    thanks again
    FRANC
  5. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Don't think they are region specific, as the screen is not fussy if it's PAL or NTSC you feed it. The back of AV amps is not a pretty sight, concrete monstrosities in Brum do spring to mind! Screws, can't remember that bit, suck it and see!
  6. Member 14847
    Member 14847
    Aug 16, 2002
    491
    28
    +54
    It is a five minute job to change. There a 4 small Phillips screws which you should treat with care as they are made of rather soft steel. One thing to note though: if you have the screen on a pedestal stand then you'll need to take it off or loosen it and have a friend hold the screen up as the card is too "tall" i.e. the connectors touch the base of the pedestal whilst the top of the card is still in the socket.
  7. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    23,759
    The Borders
    +2,463
    franc
    If your going to attempt an 'in situ' swap out please ensure ALL of your kit is disconnected from the mains.
    I'd stick to an 'in region' board - they do differ; some regions modify the timings on the S-video input for example.
    Best regards
    Joe
    PS Use a magnetic screw driver and a white sheet on the floor - they are very small and fiddly screws!
  8. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Round at the neighbours last night, the small and fiddly screws must be why he's just got the holes for them! Lovely stripped floor, nice gaps in the planks.....
