Terminal boards
Discussion in 'Plasma TVs' started by adymartin, Feb 7, 2005.
  1. adymartin
    adymartin
    Jan 27, 2005
    128
    16
    right! definitely a panny 6 or 7. but i have one more question. do the terminal boards just slot into the back as easy as pie or is there some kind of electrical DIY needed to get everything connected I.e. soldering etc?
    also is there more than one slot available, i.e. could you have two scart ternimals and a composite for instance?
    sorry to be such a blithering idiot, but this is all new territory!!
  2. geeWcee
    geeWcee
    Oct 27, 2003
    1,402
    West Yorkshire
    +25
    Terminal boards go in quite simply. Its just held in by 4 screws.
    I have the PW7 and it has room for 3 boards, not sure about the PW6 but presume it will be the same.
    I have 1 scart, 1 component and one s-video. Looking for a HDMI though!
  3. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    couldn't be easier to fit
  4. adymartin
    adymartin
    Jan 27, 2005
    128
    16
    cheers fellas! peace of mind is firmly in place!!
