Tell us about your 43MXE-1!!
Discussion in 'Plasma TVs' started by X-Factor, Jul 5, 2004.
  1. X-Factor
    X-Factor
    Nov 1, 2003
    57
    Scotland
    I believe a couple of people have taken delivery, how are you getting on with them??
    I'm 95% convinced I'm going for the pioneer over the Panny hd6 for connection to a HTPC but want to know if anyones come across any issues before I take the plunge.
    Ta
  2. Triggaaar
    Triggaaar
    Apr 13, 2003
    5,571
    +1,016
    I'm in exactly the same position with the 50" version (maybe a slightly higher percentage).
    Has anyone got a MXE1 properly calibrated?
  3. Blu-rayx
    Blu-rayx
    Nov 6, 2001
    2,102
    n/a
    +214
    At the moment my MXE-1 was setup by joe fernand(The Media Factory) before it was delivered,the settings are very good,but it was advised not to calibrate it furthermore until the screen has been running for 100 hours.
    I've got 50 hours to go!!
    DVD
  4. Vinesh
    Vinesh
    Dec 23, 2002
    776
    28
    +31
    I've had my screen for a week and running the lumagen vision.
    Pictures are stunning and still running the screen in.
  5. bamber
    bamber
    Dec 2, 2002
    212
    16
    Had my 50MXE-1 for over three weeks now and am most impressed. It's better than my 503MXE but the Lumagen makes a big difference. :thumbsup:
  6. Rob
    Rob
    Jul 17, 2000
    1,279
    Norwich
    +33
    Which Lumagen Are you guys using, the DVI or the older vision?
    Cheers Rob.
  7. bamber
    bamber
    Dec 2, 2002
    212
    16
    Hi Rob,
    I use the new Pro HDP SDI in DVI out haven't had any issues with 50Hz etc.
    Gaz
  8. Gordon @ Convergent AV
    Jul 13, 2000
    13,982
    +2,786
  9. Triggaaar
    Triggaaar
    Apr 13, 2003
    5,571
    +1,016
    Hi Gordon,
    Have you managed to calibrate a MXE1 yet? If so, what do you think of them compared to the PHD6?
  10. Vinesh
    Vinesh
    Dec 23, 2002
    776
    28
    +31
    Yep i've got the orignal Lumagen Vision
  11. Rob
    Rob
    Jul 17, 2000
    1,279
    Norwich
    +33
    Gazza,
    What sources do you route through the lumagen?
    Cheers Rob.
  12. bamber
    bamber
    Dec 2, 2002
    212
    16
    Hi Rob,
    I'm running the Arcam DV27A (SDI) and a Digibox (RGB Sync on Composite). I'm currently trying to track down a V1 Sky+ box. Once my room is finished I will hopefully route everything through the Lumagen.
    What are your plans Rob?
    Gaz
  13. bartbs
    bartbs
    Got my 50mxe1 for 1 day now. Looks great. I am using an iscan hd for scaling, dvi at native res. 50hz no problem! There is no internal framerate convertion in mode 2.
    Looks a bit better than my 503mxe but not that much.
    Bart
  14. Triggaaar
    Triggaaar
    Apr 13, 2003
    5,571
    +1,016
    Who set your MXE1 up for you Bart? Why did you change the 503mxe (or have you now got two)?
    Given that I'm planning to order the MXE1, I'm hoping its more than a bit better than the 503mxe.
  15. Rob
    Rob
    Jul 17, 2000
    1,279
    Norwich
    +33
    Gaz,
    Well I was going to connect my HCPC directly to the DVI in, and everything else through a standard Lumagen Vision via the VGA port, but I've managed to pick up a used vision HDP (not pro) so I can use the DVI passthrough on that for the PC.
    DVD player will just be component, Freeview box I was planning to use a RGB- component converter but If it can be configured to take an RGB source, even better. The only other source is a VCR, although I probably won't use this much. Handy to use if needed as an analog tuner though.
    Regards Rob.
  16. bamber
    bamber
    Dec 2, 2002
    212
    16
    Hi Rob,
    The RGBS connection looks really good, it suffers the odd breakup now and again (nothing to worry about). I think this is to do with the digi box scart connectors. Reading other threads, I think they be looking into this.
  17. bartbs
    bartbs
    Hi Triggaaar,
    I bought the 50MXE1 to be able to use the plasma with a scaler/videoprocessor, dvi in, 50hz. With the 503MXE this is possible but not without "motion judder" since the 503 will convert all native rate signals (pal) 50hz to 70hz. Some can live with this but i just don't like that. The 50MXE1 has a framerate convertion option that allows 50hz to maintain 50hz without convertion.
    The picture from the 50mxe1 is a bit better than the 503 but realy not that much. It uses the same glass with some new features. The biggest improvement is that you can drive it native, dvi, without judder. I set up the display myself. I will wait a couple of months before having it calibrated.
    A scaler absolutely improves the pq. It also has some downsides. It softens the picture a bit (to remove the croma bug i guess) and it makes the picture look a bit more "digital" but sure more detail, 3d effect and less noise.
    Bart
  18. bamber
    bamber
    Dec 2, 2002
    212
    16
    The 50MXE-1 uses the same glass as the 504HDE not the 503MXE.
  19. bartbs
    bartbs
    And the 504 uses the same glass as the 503 according to pioneer benelux.
  20. SimonO
    SimonO
    Nov 4, 2002
    3,193
    71
    Hertfordshire
    +64
    504 uses the same glass as the 503 but has a new front filter...
  21. Triggaaar
    Triggaaar
    Apr 13, 2003
    5,571
    +1,016
    Thanks Bart
    That maybe what's best for you, but if you haven't already, try the MXE's FRC mode 2. It will convert 50 Hz to 100 Hz, and leave 60 Hz untouched. Joe tells me he's found it very good so far.
    I too have head that there's a screen change. Although the glass maybe the same, they've changed the film or filter.
  22. Rob
    Rob
    Jul 17, 2000
    1,279
    Norwich
    +33
    Gaz,
    What lead did you use from your digibox to lumagen and where did you get it?
    Cheers.
  23. bamber
    bamber
    Dec 2, 2002
    212
    16
    I got Elliot at PJ Hifi to make a VanDamme SCART to 4 bnc cable which is R G B and sync on Composite out.
    Gaz
  24. Rob
    Rob
    Jul 17, 2000
    1,279
    Norwich
    +33
    Thanks Gaz,
    So you use R, G, and B for the Y, U, & V connections of the Lumagen, and the composite to one of the composit inputs?
  25. bamber
    bamber
    Dec 2, 2002
    212
    16
    Thats correct.
    I use input 3 (RGBS) and the composite goes to input 5 (svideo/composite).
  26. Rob
    Rob
    Jul 17, 2000
    1,279
    Norwich
    +33
    Great :smashin:
    I'll get a lead made up ready. not too long now hopefully.
    Rob.
  27. Rob
    Rob
    Jul 17, 2000
    1,279
    Norwich
    +33
    Gaz,
    Have you noticed if the Lumagen causes a lip sync delay? I'm not sure if I'm able to change this in my current amp.
    Thanks again
  28. bamber
    bamber
    Dec 2, 2002
    212
    16
    Haven't noticed any lip sync delay.
    After watching a couple of films yesterday I did notice some shutter using 50hz on the 50MXE-1 so it looks like mode 2 is definately converting to 100Hz.
    Hopefully someone will find a way of bypassing internal FRC.
    Gaz
  29. JensH
    JensH
    Jul 6, 2004
    85
    +9
    Would it be possible to feed it with a 75Hz signal and have it run at native rate?
    Jens
  30. Triggaaar
    Triggaaar
    Apr 13, 2003
    5,571
    +1,016
    Info from Joe Fernand:
    Mode 01 - 50 Hz and 60 Hz are converted to 70Hz
    Mode 02 - 50 Hz is converted to 100 Hz, 59.94 and 60 Hz are left untouched.
    Mode 03 - is only for use with 24 FPS HD video cameras
    Disappointing that you found problems with 50Hz in mode 2. I wonder if it would be best to start collecting region 1 DVDs instead of PAL.
