telewest?
Discussion in 'Cable TV & Virgin Media TV' started by wilkesy, Oct 28, 2005.
  1. wilkesy
    wilkesy
    Hi i emailed telewest asking what tv tuners they enable to watch telewest digital with, and they came back with "none"... so basically saying they dont have any tv tuners that we can use...
    is this bullshizzle!? does anyone know of a card that works with telewest? i would really like to have this work with media centre edition...
    Thanks guys!
  2. MacBurp
    MacBurp
    Aug 9, 2005
    262
    28
    +22
    First thing to understand is that Telewest does not support HTPC. You will get no help there. :mad:
    The only way to connect encrypted TV (cable, satellite) to an HTPC is to take an analogue feed from the box. This may change when Windows Vista comes along - I'm not holding my breath. For Telewest you will need
    - RGB - Svideo converter (check out Maplins for this)
    - Scart-Svideo cable (Maplins again)
    - Redeye IR converter (www.redremote.co.uk)
    - analogue TV tuner (eg. Hauppauge PVR150 MCE)
    good luck.
    regards,
    Paul
  3. Spacecat
    Spacecat
    Apr 1, 2001
    3,443
    London
    +1,121
    i use the ATI 550 pro(not the hauppage) with telewest using the components above .
    The picture quality is superb
  4. wilkesy
    wilkesy
    hmmm... what a pain in the ass! why the hell dont they just support this! they will increase there customers, not lose them! FOOLS!!
  5. nigelbb
    nigelbb
    Apr 4, 2005
    5,309
    103
    +491
    Just like Sky the cable companies don't want to support 3rd party PVRs as they want you to be locked in to theirs. Even if Telewest don't currently have a PVR they certainly have plans particularly after they merge with NTL as they need something to compete with Sky+.
  6. deksawyer
    deksawyer
    May 26, 2005
    1,641
    Fife, Scotland
    +132
    There are plans/rumors that Telewest are to release a 3 tuner hard drive based PVR, but last time I heard it was a bit hush hush......
    D.
  7. makey
    makey
    Mar 11, 2004
    202
    28
    +35
    defo releasing the 3tuner with hard drive box
    seen one the other day
    is in the process of trailing it at the moment
    so should be out shortly
  8. Spacecat
    Spacecat
    Apr 1, 2001
    3,443
    London
    +1,121
    percentage wise we are insignificant , so they will not invest in us
  9. CDphobe
    CDphobe
    Jul 11, 2004
    1,128
    48
    Bolton
    +89
    Really? I've not tried any post processing on the Telewest signal yet but straight through to the display (CRT or PDP) my picture suffers from terrible colour blocking (which I assume is a digital compression artifact). Does your HTPC processing remove this or do I need to start ranting at Telewest again?
    Al
  10. MacBurp
    MacBurp
    Aug 9, 2005
    262
    28
    +22
    You need the best quality picture from Telewest before putting this into the HTPC, as the picture will be degraded to some extent.
    Check if you have the Telewest signal set to RGB, and the box is hooked up to an RGB Scart on the TV. Are you using good quality Scarts?
    Paul
  11. CDphobe
    CDphobe
    Jul 11, 2004
    1,128
    48
    Bolton
    +89
    Kinda what I expected Paul. Output is set to RGB, going to the correct SCART using QED AV2110 Sqart cable. And as I say, I get what I think are mpeg artifacts on both a Panasonic CRT and an LG PDP. Extremely obvious on Sky One, but also a significant degradation compared with analogue on the usual BBC1 through Ch5. Looks like I need to ask about bandwidth.
    Al
  12. Spacecat
    Spacecat
    Apr 1, 2001
    3,443
    London
    +1,121
    i use a scart top Svideo convertor to take the signal into my
    Ati 550 Pro and then a VGA to scart cable from PC to a Loewe CRT.
    I find the picture quality on most channels to be virtually indistinguishable from the straight telewest signal
