Stupot43
Can anyone tell me what is output from the 2nd scart socket on the digibox when the settings are for RGB output. I know this sounds self explanatory, but I don`t know if it set the output on the AV2 also or whether it is for the AV1 output only?
The reason I want to know is so that I can put a RGB to y/c converter in line from the av2 on the digibox to the vcr so that I can record programmes in y/c rather tham atrocious composite.
Any help would be appreciated.
Thank You.
Thank You.
