Telewest Digital Cable Box..
D
Dazed
I'm not sure if this query has been answered on the forum before so I'll plow on regardless :)
I subscribe to Telewest Digital - I have a PACE box but unfortunately this does not have any audio outs - what I've been doing is just running a connection from my TV to my amp. This isn't really ideal.
Does anyone therefore know if Telewest supply any sort of different boxes with audio outs and how I could go about getting one (hopefully free)
Cheers all
Chris Muriel
Surely it has a SCART socket from which you can break out or tap off the audio .
You can even buy Scart to phono adaptors that do this. You may also need a SCART splitter lead (duplicates the SCART connections at the rear of the Cable-box) so you can maintain a direct SCART connection to the TV at the same time.
Chris Muriel
pat clancy
my telewest box has audio left and right out,not that its any good though,the sound that is, rgrds pat
D
Dazed
Jason
Thanks that looks just the ticket. Incidentally where do you get those cables you mentioned made up - at Maplins as well?
J
Jason S
I got the cables made by Keene Electronics, although they were only they were RGB + C only and I added the pin 8 & 16 afterwards (cos I forgot to ask for them to be made up).
Scary opening up £30-40 worth of cable and attacking with a soldering iron!!!
Keene will do the custom cables though with those pins just call them up and ask them.
Chris Muriel
The box from Maplin was exactly what I was trying to suggest.
I guess I need to verbalise better :)
Chris Muriel
MAW
Breakout from scart is the way to go regardless of connectors on Pace boxes, the phonos are a joke, they're dual mono for some strange reason. Or at least they are with NTL, can't see they'd be different with a different cable co.
Similar threads
LG CX 4K OLED TV Review: The best TV of 2020?
