telewest cable
Discussion in 'Cable TV & Virgin Media TV' started by martin.froom, Mar 21, 2002.
  1. martin.froom
    martin.froom
    Hello,
    I have recently purchased a WF82 3020A Grundig Widescreen TV and need some help and advice. On normal analogue tv the picture is in widescreen format but when I use my telewest cable digital box the picture jumps between 16:9 and 4:3 format on certain channels. I have set the cable box to the 16:9 setting and tried to store the 16:9 setting on the tv but if I turn the cable off and on again certain channels go back to 4:3.
    When it reverts back to 4:3 the tv setting reverts back to auto. Is this a problem with the tv or the cable?
    Martin Froom
