Telewest and RGB vs Composite
Discussion in 'Cable TV & Virgin Media TV' started by Phandaal, Apr 10, 2003.
  1. Phandaal
    Phandaal
    Aug 15, 2002
    274
    +7
    I had telewest digital installed a couple of days ago and it is set up with the RGB cable from the pace box to the RGB socket on the back of my FS76.
    I think the picture is pretty poor with ghosting occuring
    When I switch it to composite the picture quality improves drammatically - no ghosting and crystal clear.
    I thought that RGB would give me the best picture so has anyone got any ideas why this could be?
  2. Fernsehman
    Fernsehman
    I've never heard of an FS76 TV set but are you certain that it's compatible with the RGB output from your box? Sounds as if it isn't.
    Fman
  3. Phandaal
    Phandaal
    Aug 15, 2002
    274
    +7
    The TV is a Sony FS76 and it has 2 RGB scart sockets - one for my cable box and one for my DVD player so I think that there should not be any compatability problems.
    When I play DVD's I do not get any ghosting so I am pretty sure its no the TV itself
    Any ideas much appreciated
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    telewest have there setup menu backwards???
