Telewest and Mac questions
Discussion in 'Cable TV & Virgin Media TV' started by raigraphixs, Mar 9, 2006.
  1. raigraphixs
    raigraphixs
    Jul 11, 2001
    65,426
    +25,745
    1. Anyone using teleswest broadband with apple mac?,
    just checked their min requirements, which may be out of date..
    http://www.telewest.co.uk:80/motive/system_requirements_bbi.pdf
    1b. Never heard of a NIC card, is that same as a ethernet port?.
    2. *Do you get a modem and a router from them?.
    I want to use both mac and xbox.
    3. Would i need a additional IP address at extra cost?
    3. Telewests own protection sofware is incompatitble with macs, so will their hardware* have any kind of firewall?
    thanks
  2. dodger747
    dodger747
    May 5, 2005
    2,976
    Liverpool
    +209
    Not really the right thread to post it in but.
    I use my Mac with Telewest. I didn't even need to install any software for it to work.
    You only need an ethernet port.
    You only get a modem
    Why do need 2 separate IP's?
    Macs have no virus' of yet. Only worms that you have to be incredably dim to install on your Mac... So no firewall is needed:thumbsup:
