Telephone Line and SKY+
Discussion in 'Sky Digital TV Forum' started by AVFan_01, Oct 20, 2005.
  1. AVFan_01
    AVFan_01
    Feb 2, 2005
    121
    UK
    +83
    I have recently joined up with SKY+. I do not have multiroom, or another sky box. Just the one SKY+ box. Can sky tell if I do not plug in my telephone line?
    I know if I had multiroom, they "Ping" the sky box via the satellite, that then makes a phone call back to base.
    However do they still do this if you have the one box?
    Thanks for any help.
  2. fortean
    fortean
    Nov 28, 2004
    825
    Chorley
    +71
    They will tell your Sky+ box to call in. When it doesn't they will assume it's not connected to a phone line. They can also place a no-ring call to your phone number. The Sky box uses the CLIP to decide if it should answer an incomming call.
  3. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,033
    Harrow, NW London
    +600
    tbh i dont see the big fuss people have about this.......get a phone cable, tack it to corner of the wall/floor internally or run it around the house externally to the room with the box.....it aint exactly difficult...lol
    unless of course you dont own a phone line, in which case Sky wouldnt let you sign up in the first place...lol (or if you have it cancelled after Sky install......in which case its at your own risk...heh, but face it, if you can afford Sky then you can afford a phone line..lol)
  4. samjet
    samjet
    Jan 1, 2005
    1,419
    38
    notts
    +5
    your help please
    my parents are about to sign up to sky+ - however to get a phone line to the sky box is going to be VERY difficult to say the least
    so is it essential or is there another option??
    thanks
    PS from my reading of the sky t&c they say something about asking you to connect a phone line to the box - not insisting upon it
    all this is quite funny because if ever you get a problem with your phone line the first thing BT tell you is to disconnect it from your sky box :eek:
  5. Daddy k
    Daddy k
    Jul 19, 2004
    9,083
    coventry
    +1,351
    when i had mine done they ran the ext in for me.
  6. samjet
    samjet
    Jan 1, 2005
    1,419
    38
    notts
    +5
    the problem in my parents case is that they have a very large house and the sky box will be a long way from any phone point
    and there is NO WAY given their very expensive finishes etc that they are going to have a cable running round the room and nailed to the walls/skirtings - and don't lets even get into the question of under the carpets :devil:
  7. mh123
    mh123
    Apr 2, 2005
    708
    Offshore UK
    +77
  8. samjet
    samjet
    Jan 1, 2005
    1,419
    38
    notts
    +5
  9. sparkybun
    sparkybun
    Jan 6, 2002
    1,267
    EN8 area
    +25
    hi,
    If you purchase your own sky+ box you do not need to connect to phone line, If the box is supplied by SKY, i.e subsidised then it does need to be connected to the phone line.
    Mel
