Techwood Twp4210
Discussion in 'Plasma TVs' started by deano40, Jan 17, 2005.
  1. deano40
    deano40
    Jan 17, 2005
    CAN ANYONE PLEASE HELP A FOOL, I HAVE BOUGHT A 4210 FROM A RETURNS AUCTION WITH A SMALL CHIP IN IT, THIS IS NOT THE PROBLEM, IT DOESN'T HAVE A TUNER BOX , CAN ANYONE HELP ME AND TELL ME WHERE TO GET A BOX FROM OR CAN I USE A DIFFERENT BOX FROM ANOTHER MANUFACTURER, I ALREADY HAVE A HITACHI 5200 AND WANT THIS ONE FOR MY LOFT TO KEEP MY TEENAGE KIDS AS FAR FROM ME AS POSS WHEN THE FOOTY IS ON !! I CAN'T FIND ANY WEB SITES WITH ANY SPARES ON THEM OR EVEN A MANUFACTURERS SITE...HELP :oops:
  2. anuvid
    anuvid
    I'm sure you could use any tuner box with the correct connection for the plasma. What did you pay for the plasma ? And where's the returns auction ? I wouldn't mind a go.
  3. deano40
    deano40
    Jan 17, 2005
    I Paid £300 Quid For It, And Its Every Thursday In Manchester, Sells All Sorts Of Stuff By The Pallet Load, Some Decent And Some Not So Good...i Also Got A Few Other Bits With The Screen For My 3 Ton... I Need To Definately Know That Another Tuner Box Would Be Compatible And Which One To Buy..cheers For Replying So Quick..
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    if it is legit not knocked off then mastrecare are your only option...if its knocked off you are knackered
  5. deano40
    deano40
    Jan 17, 2005
    I Have Been On To Mastercare And They Say That They Don't Sell The Tuner Box On Its Own, They Used To For £300 But No Longer Do, They Couldn't Even Give Me A Website Or Contact Details For Techwood..
  6. anuvid
    anuvid
    Ok, which connectors does a Techwood have ? Scart ? DVI ? HDMI ? There must be a third party tuner that works. Which sources will you be using in the loft ?
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    TECHWOOD is a DSG own brand (dixons Currys) mastercare are their supplier but obviously decided selling the bits to make nicked screen work was a mistake...........
    the tuner is not a standard unit could try the awful DAEWOO from RS.. or a ProV but needs to be VGA connection also you will lose all screen control etc..... and access to setup menu.......
    I am afraid to say that your £300 has been wasted.... (if it sounds to good to be true then it usually is)
  8. AndrewTheMuppet
    AndrewTheMuppet
    Dec 3, 2004
    195
    +3
    Ok, the Techwood has scarts.
    So just get a freeview box and you're sorted.
    I've seen freeview boxes for as little as £50.
    Surely this is the answer.
    Or am I missing something.
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    scarts on the 4210 are located on the missing.......tuner unit...there is only one connection on screen, for tuner box.............
  10. anuvid
    anuvid
    Yeh but I think that connector is a DVI or HDMI connector. There is kit you could test with it for sure. Did you not get the remote either ?
  11. deano40
    deano40
    Jan 17, 2005
    I did get the remote and speakers just missing the bit that makes it all work !! The only socket on the back apart from the power supply one is one marked lvds-in.. Not too sure what type this is as my hitachi has everything else except this type.. My kids want it for ps2 , dvd and x-box..
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    tis for media box......can you post a photo???
  13. deano40
    deano40
    Jan 17, 2005
    what bit do u want a photo of ??
  14. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    the connection on rear of screen mate
    as much deatil as possible
  15. deano40
    deano40
    Jan 17, 2005
    How do i make picture small enough to be able to post as every time i try and post it says file too big...??
  16. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    use a photo editor to shrink it or put it in an online gallery and link to (make sure its public album) try photobucket
  17. sldt
    sldt
    Does it look like this?
    It is the tuner lead from a Techwood
  18. zygote
    zygote
    Deano40, try contacting Goodmans. The Techwood is exactly the same unit as the Goodmans GTV-42P2.
  19. SLIM
    SLIM
    Jan 1, 2004
    1,352
    38
    +17
    flog it on EBAY
  20. AndrewTheMuppet
    AndrewTheMuppet
    Dec 3, 2004
    195
    +3
    Find someone else whose got a techwood and nick their tuner box!!!
    Ok, I'm joking. Looks like you're stuffed. :suicide:
    Thanks hornydragon for putting me straight about the scarts. Next time I'll shut up when I don't actually know what I'm talking about. :blush:
  21. anuvid
    anuvid
    What would you sell it for ?
  22. bob1249
    bob1249
    May 1, 2008
    Hi mate i have a box for sale for the techwood 4210 plasma drop me a line at tbobv@btinternet.com all the best Bob
