TECHWOOD TWP4205PL 42" plasma
Discussion in 'Plasma TVs Forum' started by mustochio, Apr 12, 2005.
  1. mustochio
    mustochio
    Please help advice needed, Found a deal in Currys Techwood twp4205pl with glass stand and dvd recorder and speakers and table top stand all for £1.199,
    thought this was a good deal and was wondering if anyone has any experience of this make and model? Would appreciate any thoughts you have, thanks .
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    try a search they are cheap but not great £1300 gets you an LG PX11, £1500 sneeks an panny PWD6/PW7 with 5.1 sound
  3. w3dal
    w3dal
    Aug 4, 2002
    5,053
    Chelmsford, Essex
    +588
    i think mep on here had a techwood. He now has a PW7.
    I have seen a techwood in action and it was an ok screen but wanted more for my money so went to av sales and got a PW7. One of the best purchases i have ever bought.
    Dal
  4. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    Dal it was a tiny actually but I'm sure they are similar ;-)
  5. w3dal
    w3dal
    Aug 4, 2002
    5,053
    Chelmsford, Essex
    +588
    I knew it would of been the other one......
    Still didnt think it was great for the money.
  6. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    correct :)
  7. mustochio
    mustochio
    Thanks for the replys so far, would £1300 get you just a plasma screen or would it come with extras? thanks. And Mep can you tell me if you was pleased or not., cheers.
  8. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    not so far with the tiny, but replacement on route..so fingers crossed....delighted with the panasonic mate. If you want more of a telly than just a screen for that budget you may want to look at the LG...you'll see quite a few threads about it.
  9. mustochio
    mustochio
    ok thanks i will do a search for LG, cheers mate.
  10. Pooon
    Pooon
    Dec 26, 2002
    7,367
    Canterbury, Kent
    +962
    If you pop into Dixon$ they are selling 'Pre-Owned' Techwood plasmas for £998, which apparantly are available in 'most' stores.
    So i think you gotta ask yourself "Where did they all come from?"
  11. mustochio
    mustochio
    Exactly prob best steer clear, but it seems such a good price!! There is so much to consider with these plasmas, i dont know what to do ???
  12. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    cheap doesn't equal good value mate. What is your ideal set up...a big telly with speakers and tuner built in...or a screen with surround sound and tuner seperates?
  13. mustochio
    mustochio
    I think the first one- big telly , good sound, but not too complicated, if you know what i mean?
  14. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    well look at the viera and LG, as they come with tuners, speakers etc out of the box....but do view them
