Techwood TWD28RF1 vs Thomson 28WH403
Discussion in 'TVs' started by max of london, Oct 1, 2004.
  1. max of london
    max of london
    I was just about to order the Thomson 28Wh403 for £325 when I saw the Techwood TWD28RF1 on the Curry's website for £249. Is the Techwood any good? (I can't find a single review on it). The Thomson is 100hz etc but at this price range is there any real noticeable difference? I'm on a tight budget so the less the better. :smashin:
  2. max of london
    max of london
    Actually I am interested in any flat screen 28" widescreen around £300 so if anyone knows of anything better than the above I would be grateful.
    Thanks :thumbsup:
  3. brummybloke
    brummybloke
    Jul 18, 2004
    85
    there is a code for currys giving you an extra 7.5% off so it is even cheaper .
    only thing i would say is you normally get what you pay for in tv's. if you want it for a couple years and are going to replace it, fine.
    but after going for the cheaper end (not through choice) and having to replace every year and a bit, i spent bigger and it lasted me for 5 years. this time round i spent abit more and i hope this mofo will last me until i can get me a 50 inch lcd.
    (at least 5 more years).
  4. max of london
    max of london
    Thanks for the code. Yes I plan to only have it for 2 or 3 years and then get a plasma hopefully (if they are any good by then).
  5. brummybloke
    brummybloke
    Jul 18, 2004
    85
