techwood plasma
Discussion in 'Plasma TVs Forum' started by electricery, May 14, 2004.
  1. electricery
    electricery
    May 14, 2004
    25
    herts
    Does any one know if you can get an longer cable for the connection between Techwood Plasma and the tuner box, the lenght of the cable supplied with the techwood plasma when fitting the unit to the wall and placeing the tuner box into a cabinet is not long enough need about 1.3 mtrs.
    thanks
    electricery::eek:
  2. BiggieBig
    BiggieBig
    Jan 3, 2004
    1,295
    48
    London
    +29
    If it's a VGA cable (same as PC display cable)
    then all you need is a VGA (HD-15) male to male cable
  3. electricery
    electricery
    May 14, 2004
    25
    herts
    Thank you depsi.
  4. atacam
    atacam
    Jul 19, 2004
    460
    Southned on Sea
    +9
    I bought a 5m one through partmaster through curries.
