Techwood Plasma & Progressive Scan
Discussion in 'Plasma TVs Forum' started by T2Dex, May 24, 2005.
  1. T2Dex
    T2Dex
    Feb 7, 2004
    40
    Hi All.
    I have had my Techwood Plasma for ages now (And Love it).
    I have been given a NEW Tishiba SD-241ESB DVD player with Progressive Scan.
    How can I take advantage of the prograssive scan....
    I dont think the Plasma has Component Input, So is there any other way of connecting it and getting the picture any better then the RGB Scart I currently use.
    I ask this as I want to try to make use of the Progressive scan on the DVD player I have just got (FREE)...
    Even if there is any other equipment I need could you please help
    Cheers All
    Dex
  2. johndon
    johndon
    Feb 3, 2002
    1,971
    63
    +108
    AFAIK, you can't get a progressive scan signal through scart so, if the plasma doesn't have component inputs, you're stuck with RGB scart.
    John
  3. T2Dex
    T2Dex
    Feb 7, 2004
    40
    Cheers for the Help mate, Never mind its good anyway
