Techwood Help
Discussion in 'Plasma TVs Forum' started by Johnnyhotspur, Dec 6, 2004.
  1. Johnnyhotspur
    Johnnyhotspur
    Just purchased the techwood 4210, reasonably happy except for picture quality during dark scenes.
    Picture seems very annimated and fazed, is this the norm for plasmas or can I improve the quality ?
    Have tried the monster scart without any real improvement, any advice would be grateful.
  2. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,149
    Hampshire
    +76
    the techwood is cheap and that means u dont get a very good picture from it. I believe it is a fujitsu rebadged (one that is a few years old and is mass produced in korea) not recomended for home cinema really. should of got a panny for a couple of hundred more.
  3. brackenlamb
    brackenlamb
    Oct 14, 2003
    421
    take it back and get a panasonic if possible
  4. avanzato
    avanzato
    Jan 21, 2003
    1,963
    Norfolk
    +82
    Well I don't own a Techwood or even a plasma but yes you probably can improve the picture from it.
    Every screen I've ever had benefited from turning off any digital noise reduction in the menu and turning down/off the sharpness control. That's if the Techwood has those options. Getting the brightness and contrast levels right is also vital for a good picture, either buy a test disc or use the THX optimiser from a retail DVD, if you own one that has it on. Do that and the picture will be looking as good as you can make it. :thumbsup:
  5. oscarmadfish
    oscarmadfish
    brightness=60
    contrast=30
    sharpness=0
    color=40
